944freak's Avatar
Send a message via Yahoo to 944freak
951 model car on ebay
It's not mine. Just thought someone might be interested.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3114202906&category=2505
1983 944
Old 02-15-2003, 06:32 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
If only someone made a 1:18 scale model...
speaking of which, there is an awesome Carrera GT 1:18 scale that I've seen around lately... not as cool as the DeLorean one though!
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 02-15-2003, 09:20 AM
Non Compos Mentis
I've got a couple 1/43s. Great detail, but don't take up too much room on my desk.
Old 02-15-2003, 12:40 PM
J1NX3D's Avatar
check out this fine example:
My original plan was to make functioning doors and hatchback, (a phase I was going through at the time). I cut them all open to discover I did not have a good understanding of hinges and working parts, and I wound up putting the model away for 12 years!
184 scratchbuilt parts were added to this kit, and 95% of them reside under the hood. Some features that I especially like are the translucent fluid containers that flank each wheel well. I had to grind out the molded-in containers, rebuild the wheel well, and then replace the containers with scratchbuilt ones with fluid in them.
The containers took many experiments and attempts to come up with what you see here. Despite the work and time involved, I was determined to make these parts look realistic, because I was convinced it would lend life and realism to the engine bay. It was also a detail that I had never seen done before. It's a feature that I would like to apply to future subjects where applicable.
The intake manifold was adjusted in many places to reflect the original and to properly fit the intercooler hose. Throttle linkage was added. Elsewhere, fuel injector lines, a distributor with wiring and ignition coil, a working dipstick with a touch of fresh oil at the tip, master brake cylinder with brake lines and turbo heat shield, wiper fluid lines, retractable headlight motor and lifting mechanism, warning decals, and car serial number on the firewall all add to the realism. A complete build list follows for those interested.
One mistake was scratchbuilding and installing a part for which I was unsure of its use. It turns out I added an air conditioning part that was removed for racing!
Photo references were abundant for several reasons. First of all, though lightly modified for racing, this is really a production car, and the engine retained most of its production parts. Second, I had years to accumulate references from magazines of the actual race car, from local race events where 944s were present, auto shows, a friend's car, and my local Porsche dealership. I feel that one can never have too many references.
Corrections Under Hood
Removed molded fluid containers and reshaped front fenders.
Replaced with real translucent plastic containers in the same shape
as the originals and filled them with "fluid".
Caps and fluid lines created according to photo references.
Created fluid pump for wwipers
Corrected inaccurate intake manifold
Replaced inaccurate distributor. New distributor created to lead 4 spark plug wires to cylinders and 1 wire to ignition coil.
Replaced inaccurate master brake cylinder with a correctly proportioned assembly complete with brake lines, authentic photo based decals, fluid level sensor, etc...
Brown production carbon canister removed as per racing version photos.
Canister bracket created as on original car
Shock tower tops created as on original car
Other Corrections
Molded door handles dug out and reapplied to bodywork
Replaced kit molded hoodpins with functional PE hoodpins.
Exhaust tip drilled
Parts Built from Scratch
Large and small fluid containers
Master brake cylinder
Functional dipstick
Sparkplug & ignition wires
Ignition coil
Distributor
Carbon canister bracket
Injection assembly
-Bracket
-Injector lines
-2 fuel regulators
Hood latch assembly
-Latch
-Latch plate
-Frame section for hood latch
Retractable headlight motor assembly
-Motor
-Brackets
-Mechanism
Tube above headers
Throttle Linkage
Fuse box quick release clips
WWiper fluid lines
Shock tower tops
Hood prop assembly
A/C parts
Rubber seal on top of Turbo heat shield
Intercooler hose fittings
Shock tower bracket assembly
Intake manifold corrections
-hoses added
2 cylinders on fender corners
Hose w/part from intake to turbo
Hood pin assembly
Brass engine lift
Baby blue thingey
Cable ties
Miscellaneous wires and hoses
Decals
-Girling yellow label
-Blue label
-Serial number
Wheel valve stems
'86 944S3 conversion
Old 02-15-2003, 05:46 PM
justin's Avatar
Thats awsome!!
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 02-15-2003, 11:29 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
how long did that take you!?
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 02-16-2003, 08:51 AM
Send a message via AIM to Trevor
Great Model! When I was like 5 one of my friends had a bunch of 944 micromachines, I always wanted to find them.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 02-16-2003, 09:26 AM
J1NX3D's Avatar
WHOA! No it wasnt me!! i dont have that much patience! i ssaw these on another *cough* forum...
Old 02-16-2003, 10:49 AM
951carter's Avatar
Here is one of my 951 models.
It is not quite finished yet.
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 02-16-2003, 05:57 PM
Hunter S.'s Avatar
Thumbs up
SWEET! Killer detail!!!!
I've got a couple of the Kits
"unbuilt" for the same 951.
Hasegawa I think? Good job!
cheers, Hunter S.
86'951
P.S. This is my first post! HI Gang!
Old 02-17-2003, 03:37 AM
Writer/Teacher
CJFusco's Avatar
Love the name... although I doubt the REAL Hunter S. drives a 951...
Old 02-18-2003, 06:29 AM
Ratcals's Avatar
I like the 1/43 scale models. You can fit a lot of them is a small space. I have a subscription from these guys DeAgostini and I get two 1/43 scale models every month.
Old 02-18-2003, 07:25 AM
951carter's Avatar
I have a 1/43 944 turbo cup, but I have not assembled it yet.
It is really cool.
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Old 02-18-2003, 08:49 AM
