wing/fender stuck
So I have removed all the top screws the three back ones ,the single one at the tip that joins to the badge panel and the majority of the wing is free and loose however the small flange that runs along the side of the headlight to the tip is proving reluctant.
any tips or advice appreciated
Gaz
Old 01-13-2018, 08:52 AM
drkshdw's Avatar
There is a support bracket that holds the bottom of the fender/top of the bumper/valance to the body that needs to be removed as well. See here:
Old 01-13-2018, 09:50 AM
just to clarify its a 924s I am refurbing and I already have the front valance and badge panel removed for a respray the wing is 90% free just the small flange running along side the headlight thats reluctants to part with the body
Old 01-13-2018, 10:36 AM
9FF 9FF is offline
9FF's Avatar
Iíve found fishing line is invaluable when taking body panels off. First it cuts through any sealant so you donít end up bending a lip fighting against the bond when you remove a panel and second, it finds any and all fasteners that youíve missed as you pull it through a join. My 2c GL
Mike A
9TECHNIK | TRANSAXLE ńRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 01-13-2018, 04:39 PM
9FF much appreciated and good shout I will give that a go next not sure if I will have time today probably next weekend will let you know how I get on.
cheers
Gaz
Old 01-14-2018, 01:18 AM
FrenchToast's Avatar
I don't know if the 924 is the same, but on the 944 there is a screw that secures the front of the fender to the nose panel. You need to flip up the headlights to access it. (You can flip them up manually, remove the rubber cover on the headlight motor and twist the knob).
9FF mentions the sealant: there is a good amount of sealant on the mounting flange at the edge of the hood (where all the screws are). 3M makes a product you can use to replace this (scrape old stuff off, reapply before mounting fender). It is for vibration dampening. There might be some sealant in other places too.
Old 01-14-2018, 06:52 PM
curtisr
curtisr's Avatar
From http://www.n5mbm.net/images/Porsche924Project/fender%20bolt%20locations.jpg comes this little jem. Of course, there is one missing location and that's the bottom of the front where the valence and fender meet.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car)
1987 924s Garnet Red
1982 928 Silver (sold)
Old 01-15-2018, 06:07 AM
just an update got the wing removed today it was nothing other than the heavy underseal on the arch side of the wing holding it, gave it a few runs through with a stanley knife and it fell off so all good.
wing has a few issues though its been patched previously at the bottom and the front flange is also gone not sure whether to replace the wing or get the body shop to sort it out. would have liked to keep it original. also few bits of surface rust to sort out nothing major.
Old 01-28-2018, 04:48 AM
Try this stuff: https://www.por15.com/
Old 01-28-2018, 05:20 AM
