88 na icv
Does anyone have an ICV for an 88 NA? $200 for one seems a bit steep. Not to mention everywhere iv checked is out of stock
Old 01-24-2018, 10:05 PM
Have 944, will restore
mazdaverx7's Avatar
May want to post a want to buy ad in the classifieds section. Browse through the part out threads and see what you come up with.
85.5 944 Guards Red M456 5spd
06 BMW 330xi 6spd/ 92 Miata 5spd
04 RX-8 Nordic Green 6spd/ 01 MR2 Spyder 5spd
04 RX-8 Brilliant Black 6spd 86 Corvette 4+3
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
Old 01-25-2018, 03:34 AM
Just get one for a Saab, Volvo, BMW, etc with the same connector and barb arrangement. They did not make a special one for Porsche. My 94 968 had a BMW E30 ISV in it when I got it. Worked fine but the fittings were wrong orientation.
Maybe something like this? Is yours 3 wire?
https://www.ebay.com/itm/New-Idle-Air-Control-Valve-IAC-Speed-Stabilizer-525-i-325-IS-323-CI-328-330-XI/191792062704
I'd probably get a good clean used Bosch one myself for similar money and clean up the grungy end with some acetone and ATF. Under $20 shipped by the pick-n-pull folks on Ebay.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 01-25-2018, 04:45 AM
Contact Mark at Plyhammer Parts
https://plyhammersparts.com/
Old 01-25-2018, 06:11 AM
Dimi 944's Avatar
I have one available. Sent me an email.
Dimi P
www.fhmotorsport.com
Porsche 944 $2
Porsche 944 Turbo - 968 power/drive train
Dimi Paralanov
flyinghorsemotorsport@gmail.com
1986 Porsche 944 3.0L 16V Conversion - on track duty!
1989 Porsche 944 $2 - for fun!
Old 01-25-2018, 06:49 AM
Hi,
I had good luck, so far, with an ICV that I purchased directly from China. Search under the Bosch number (0280140501) in the usual places. Cost around $50.00.
I built a bench tester to test my original ICV. I couldn't get it work smoothly at all temperatures even after cleaning. Plus it was leaking a little. I wouldn't expect any used unit to work much better. They are all getting on thirty years old now and the wear patterns are all the same.
I got the unit form China as a stop-gap measure. It tested well on the bench and works well in my 86 944.
Last I checked, an ICV can be ordered from Porsche, if the cost is not an issue. Also, our host list the unit as in stock, ships tomorrow.
Peter
Old 01-25-2018, 08:33 PM
