Coeur d'Alene, Idaho
Thoughts on alignment 84 944?
So I'm replacing a tie rod and will be having the front end aligned. I put new front struts and rear shocks on it and the tie rod is due to a tiny felt slack on the left one. Any thoughts on using the stock front alignment vs a minor tweak? Pure road going car - not interested in track operation.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 01-26-2018, 10:39 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Hi I dialled out the understeer on my 924S with a bigger rear swaybar but left the front settings
stock. Worked ok on hillclimbs
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear swaybar.
Ford Focus 1.8TDCi estate daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 01-30-2018, 02:05 AM
Hey Doug...check this out. It has some alignment specs
TECH FORUM General Suspension Preparation 924 944 968
Old 01-30-2018, 06:50 AM
those are good numbers.
to get all four wheels to break away at the same time...on the front, 2.3 degrees caster, 0.5 degrees negative camber, zero toe pushed and 38psi with 225s. rear..1.1 negative and a strings width of toe in at 34 psi running 245s.
it took about 1000 miles to find the neutral sweet spot.
Old 01-30-2018, 03:02 PM
