225/15/50
Any pics of 944's with these tires on 15x7 rims
other tire sizes welcomed I want to get a feel for what the car will look like with different tire options
thank
you
Chip
Old 02-17-2003, 01:25 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
that's the size I'm going to get..
maybe a 235 in the rear 235/45/115
FRankB
My car is naughty
Old 02-17-2003, 02:03 PM
This is the size used by VW on early 90's Passat models. Difficult to find, and VERY pricey. Let me know what you find. I have a Passat and had to compromise with a slightly narrower 60 style. (same diameter).
Bob S. former owner of a 1984 silver 944
Old 02-17-2003, 05:55 PM
Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
I have a game of fuchs 8" with 225 50 15 new bridgestone tires, if you want I can post it.
I insist that the 225 is for 8"
Old 02-17-2003, 06:16 PM
Fuchs 8" 225 50 15
Old 02-18-2003, 07:29 AM
is your recomandation 215/55/15's for my car or do you think I should stick with the 215/60/15 I have??
83 944na
Old 02-18-2003, 10:19 AM
I recently bought tyres for my 7" cookie wheels and I bought
201-60-15
A lot of peopele here uses 225 in 7" then you can use it, for me don´t looks correct.
Ok,
up
cookie cutter 7" with 215 55 15 pirelli
down
cookie cutter 7" with 205 60 15 michelin
the 205 look wider maybe because the wall is higher
same size numbers From brand to brand change in measurements.
You can look in the tyres web pages the exact size that have each tyre.
The only advice that I can give you is:
Took out one of your wheels (rim), Go to the brand dealer of your choice and change diferent size of tyres until you find a tyre that like you, size, pattern and looks.
hope this helps
regards
Old 02-18-2003, 11:00 AM
