"Ferdinand's finest"
lowenschlo's Avatar
Death wobble at 80mph
I donít have any idea what it is but all is well until I hit about 80mph under hard acceleration I get this massive death wobble on the left side that doesnít go away until I brake hard and decrement my speed about 35mph. Any thoughts on what could cause this? Alignment checked out good, I donít think any wheel bearings are bad and my tires arenít in bad shape.
Thanks in advance!
"The fastest lap time you will ever record, will always be done behind someone else" - Yours truly
Old 01-30-2018, 05:59 PM
drkshdw's Avatar
Tire out of balance or a bent wheel.
Old 01-30-2018, 06:26 PM
Have 944, will restore
mazdaverx7's Avatar
^^^ I agree with the above. Have the tire balance checked and have each wheel checked for a shifted belt and any flat spotting. There they can determine which tires are out of balance and they can see a bent wheel or a shifted belt on a balancer. You may want to find a shop that does road force balancing. That is a very thorough balancing that may require tire removal and or movement on the wheel. The balancer will advise the tech of any issues in road force with the tire being balanced.
85.5 944 Guards Red M456 5spd
06 BMW 330xi 6spd/ 92 Miata 5spd
04 RX-8 Nordic Green 6spd/ 01 MR2 Spyder 5spd
04 RX-8 Brilliant Black 6spd 86 Corvette 4+3
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
Old 01-31-2018, 03:35 AM
Coeur d'Alene, Idaho
Explain more about the death wobble being "only on the left side". How is that being determined - that its on the left side? Also are we talking front or rear of the car? Where do you feel it - steering wheel or through the seat/floor? Any noise also happening?
You might have someone video the car from behind to see if that reveals anything.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 01-31-2018, 10:12 PM
flash968's Avatar
wobbles at a specific speed are almost always to a rotational mass being out of whack (tire out of balance, popped tire cord, bent wheel, etc)
however, i had a car do this once, and believe it or not, it turned out to be the castor block. while the initial onset was brought about by a balance issue, the root cause was a bad castor block.
Old 01-31-2018, 10:23 PM
