Diving in 911
Rear Hatch latch corrosion
Trying to get a crusty set of latches to disengage after 10 years of sitting. Took the drain caps off, took all 4 10mm nuts off, soaked in penetrant. They will wiggle by hand but itís as though the tach wonít let go of the pin. Tried prying and all it would do is draw the hatch tighter. The actuated arms on the back of the latches appear to just move back and forth with no detectable resistence. Thought about using a ball joint puller to force the pin out. Any better ideas or tips out there? It there another way to get the latch to disengage? (87 951)
Thanks!
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1987 951 Turbo
1981 928 blk/blk 5sp
Old 02-05-2018, 04:58 PM
drkshdw's Avatar
You'll do a bit of damage using a ball joint puller because the pins have a square shoulder on them so you'll have to break the claws in the latch holding the pins which won't be an easy feat.
Your other option would be using a screwdriver from underneath to try and unscrew the pins from the hatch. Original pins have a slot for a flat head on the ends so shoot the screwdriver straight up the center of the latches and hope they either let go or break (probable). Although I would use a large driver bit in a socket and use a breaker bar to get leverage to help it let go.
Old 02-05-2018, 07:08 PM
Diving in 911
I’ll give that a try. The lid, pins and latches will be replaced I just don’t want to damage the body.
1987 951 Turbo
Old 02-05-2018, 07:23 PM
