Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
hepkat63's Avatar
1980 924 NA Vacuum diagram
Hi all,
would someone please be able to post a picture of correctly connected vacuum lines for a 1980 924 NA engine? Everything I"m searching comes up with broken photobucket links or non-existing images. There are a few line diagrams, which are hard to work out.
My car starts , but won't rev and want to check that all the vacuum lines are present and connected correctly as there are quite a few that are blocked off?
Here is a picture of the engine bay, if someone can please help?
Old 02-05-2018, 11:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
your average wrencher...
Not only vacuum lines but your old seals around the injectors leak quite a bit with age. Also your throttle body/intake boots, make sure no rips in them either. Access to a smoke machine? You say many lines are capped off, obviously they are not supposed to be that way...
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 02-06-2018, 05:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
hepkat63's Avatar
thanks for the reply. Do you have photos of a correct setup you can post please?
Old 02-06-2018, 05:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Try : 77 924 vacuum line diagram?
Old 02-06-2018, 07:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
