88_944's Avatar
Where this goes?
Where does part "21" goes? WTF?
My Black 944
My Gaming Forums. Xbox360gen.com
Old 02-18-2003, 10:53 AM
Scott R's Avatar
It's a sheild that gets bolted to the bellhousing.
The picture is accurate even down to the angle. Once you get the bellhousing loose and remove the two bolts it will slip out.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-18-2003, 11:22 AM
88_944's Avatar
Ok thanks! My damn uncle helped me take of the bellhousing, by the time I came outside he took it off and didn't see where it came off. He moved out of my house and now I have to put back everything. My first time doing a clutch job.
My Black 944
Old 02-18-2003, 11:47 AM
I don't think the bellhousing has to be loose to remove it, just fyi
Old 02-18-2003, 04:50 PM
Scott R's Avatar
Probably not, mine was wedged in there pretty tight on my 85.5, but fell out of the 87. Could have been a freak thing on the 85.5.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-18-2003, 05:16 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
My 84 was pretty loose...
Ahmet
Cheers!
Old 02-18-2003, 07:31 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
I have an uncle that did that.. but it was with a bike.. he had great weed though.. as for part 21 it is a sleeve that bolts onto the bell housing see the mounting holes above 20?.. that's where ir gets bolted on, (same on other side) most of the time these bolts unscrew, and it just sort of get stuck... so check em.. clean em, and re-attach with thread lock.. check periodically....
Frank B
Frank B
My car is naughty
Old 02-18-2003, 07:41 PM
88_944's Avatar
Thanks!
My Black 944
Old 02-18-2003, 09:24 PM
