-   -   Guess the problem part 2 (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/98684-guess-problem-part-2-a.html)
AFJuvat 02-18-2003 05:52 AM
The second in the series of "test your troubleshooting skills"
Vehicle: 86 944
Mileage: 126000 miles
Clutch (spring centered), Pressure plate, TO bearing, master and slave replaced 15000 miles ago. Flywheel meets specification and was refaced at the time of clutch replacement
Car runs normally. Customer complains of clutch slipping at high RPM or at high torque. Smell of burnt clutch material.
No other noises, but customer states that the car just doesn't have the "oompf" it used to.
No further information
AFJuvat
944S Boyeee 02-18-2003 06:16 AM
Would a spring centered clutch make a burning smell???
Could the torque tube be loose??
944S Boyeee
Bob's944 02-18-2003 06:18 AM
Was just up till 2 am last night helping a friend with a ford probe gt replace his clutch. His symptoms were similar at first, but became worse. His Throw Out bearing was failing first, losing power at high RPM's and when he punched it off the line. When you would engage the clutch at low RPM's without giving it good revs, the engine would try to stall out. The next thing to start occuring was the sound of parts falling off, he was driving the car alil over a week before it was repaired. After getting the clutch out, the surface of the clutch material was ok, the TO bearing was GONE and several 'fingers on the pressure plate broke away. New clutch is in, along with a new flywheel... he's very happy.
daveimme 02-18-2003 06:23 AM
Yeah....I bet he was happy (for once) he didn't have a 944, right?
I'm curious here, too.....my limited knowledge points to the clutch springs being too weak?? (just don't laugh, ok?)
AFJuvat 02-18-2003 06:35 AM
Torque tube: No noise or vibration indicated
TO bearing: on the right track, but they usually make noise or vibrate when they start to fail.
Clutch Springs: Fine
Car is daily driver, not tracked. Owner does know how to drive a manual transmission vehicle properly - driving habits are not indicative of abuse.
AFJuvat
todwic 02-18-2003 08:25 AM
accidently replaced the 944 clutch disc with a 924 disc? hehe
SoCal Driver 02-18-2003 09:59 AM
Broken clutch fork not letting the TOB move "back" properly.
Or a cat got caught in the bell housing.
88_944 02-18-2003 10:49 AM
Small leak on the Slave Cylinder that's shooting oil on the disc. :D
PorscheG96 02-18-2003 11:02 AM
I think you're on the right track.
My guess is leaking rear main. Moral: While you're in there, might as well do this...and this...oh, that too. :eek:
ae1969 02-18-2003 12:28 PM
rear main seal
AFJuvat 02-18-2003 12:34 PM
So many that are close, and yet so far away.
Hint: As I said before, Nothing is leaking
AFJuvat
PorscheG96 02-18-2003 01:00 PM
Okay...if the clutch is SLIPPING then there's not sufficient friction on the clutch disc. Since you say there's nothing leaking, and the clutch was replaced recently, then something is adjusted incorrectly with the clutch fork/pressure plate which is allowing the disc to slip.
ilikemy944 02-18-2003 01:07 PM
The pedal is not adjusted properly - too tight, not allowing clutch to release completely.
SoCal Driver 02-18-2003 01:08 PM
OK it's not a cat.
A possum?
ae1969 02-18-2003 02:25 PM
they put the rings/clips on the throw out bearing wrong or came loose.....
AFJuvat 02-18-2003 02:25 PM
BINGO
5 minute repair, 12mm wrench and a 9mm wrench, fixed.
AFJuvat
PorscheG96 02-18-2003 02:43 PM
Where are the clutch pedal adjustments made at [just for future reference and my curiousity]? Thanks.
SoCal Driver 02-18-2003 02:47 PM
Who replaced the clutch and other items?
Roger Hall 02-18-2003 03:24 PM
Guess thats why I am not a mechanic. I would have thought TO berring was not disengaging. It would have been partial right but by that time I have allready pulled the tranny.
AFJuvat 02-18-2003 04:00 PM
Actually, I replaced the clutch.
Owner adjusted the cylinder for a "stiffer" pedal.
You make the adjustments at the clutch master cylinder - you screw the rod further in the pedal to loosen the pedal, and unscrew it to "tighten: it up.
Should have a couple of MM free play be design.
AFJuvat
