Synthetic Oil
Any recommendations on what kind to use in my car?
'83 944
Forest Green
Old 02-19-2003, 08:52 AM
AFJuvat's Avatar
Mobil 1 or swepco are proplar choices.
If you plan on changing the oil every 3k miles, stick to regular dino juice.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-19-2003, 09:05 AM
Thanks. Typically, how long will synthetic last. I heard it is better if you only use synthetic every few oil changes. Anyone know if that is true or not.
'83 944
Forest Green
Old 02-19-2003, 09:18 AM
Blackfoot's Avatar
full synthetic will not show any appreciable breakdown until at least 20k; the only problem with letting it stay in there that long is unfiltered foreign objects. wish our 944's had a top-loading filter element like my bmw...it i change filter every 5k and syn oil 10k.
Old 02-19-2003, 09:41 AM
Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Old 02-19-2003, 09:44 AM
88_944's Avatar
Want to know which viscosity is right for your 944? Go here and find out what viscosity is best for your 944. I found out on my temperature range that I need 15W-50W Mobil1 oil.
http://www.prod.mobil1.com/tools/which/index.jsp
Listed below are the oil viscosities that your vehicle manufacturer recommends for different temperature ranges, as well as the Mobil 1 motor oil that is suitable for your vehicle.
Make: Porsche
Model: 944
Year: 1988
Engine: L4-2479cc 2.5L
10W-30 -13° F to 68° F
You can use Mobil 1 with SuperSyn™ 10W-30 with confidence. This viscosity is also available in Mobil Drive Clean Oil™ and Mobil Drive Clean Synthetic Blend™.
10W-40 32° F to 100° F
Mobil 1 is not available in that specific viscosity. However, 10W-40 is available in Mobil Drive Clean Oil™. Mobil 1 with SuperSyn™ 0W-40 or 15W-50 may be alternative viscosities. Please consult your vehicle owner's manual, or contact a dealer or your vehicle's manufacturer.
15W-40 Above 5° F
Mobil does not carry this specific viscosity. Mobil 1 with SuperSyn™ 0W-40 or 15W-50 may be alternative viscosities. Please consult your vehicle owner's manual, or contact a dealer or your vehicle's manufacturer.
20W-40 Above 14° F
Mobil does not carry this specific viscosity. Mobil 1 with SuperSyn™ 10W-30 or 15W-50 may be alternative viscosities. Please consult your vehicle owner's manual, or contact a dealer or your vehicle's manufacturer.
5W-20 Below 14° F
Mobil 1 is not available in that specific viscosity. However, 5W-20 is available in Mobil Drive Clean Oil™. Mobil 1 with SuperSyn™ 0W-30 or 5W-30 may be alternative viscosities. Please consult your vehicle owner's manual, or contact a dealer or your vehicle's manufacturer.
5W-30 -22° F to 32° F
You can use Mobil 1 with SuperSyn™ 5W-30 with confidence. This viscosity is also available in Mobil Drive Clean Oil™ and Mobil Drive Clean Synthetic Blend™.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 02-19-2003, 11:02 AM
This is great. Thanks
Thanks for everyones help on this.
'83 944
Forest Green
Old 02-19-2003, 11:24 AM
I would recommend mobil 1 15/50. my 944 S2 seems very happy on this, unless you are in a location with cold winters.
Porsches recommended oil change for the 944 S2, Boxster, and new 911s is 15K miles (!), with Mobil 1. So 10K should be perfectly safe. As my car has reach 112K with no apparent engine wear with 15K oil changes and mobil 1 (done by previous owner), I feel safe running 10K oil changes (though lots of people on this board will tell you they run 3K changes. Are they wasting their money? Don't know.). No harm in changing the filter every 5K though and filters are cheap.
Mark
Old 02-19-2003, 05:49 PM
