Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Springs for an s2
Maybe my search skill are going to heck. But I can't seem to find springs that don't have some sort of small print in the description (not for s2).
I think there are h&r springs in pelicans store but what other options are there?
I don't want to order something only to find out I either need to modify something or buy something else.
Also of if I had a full turbo parts car I what would I need to swap over to make the struts work on an 89 s2.
Old 02-24-2018, 06:25 AM
Dimi 944's Avatar
The only lowering springs I know are for NA and turbo models with bigger ID. You might have to go to coilover set up in order to get different springs. Turbo struts bolt on to the S2 directly.
Sent from my Pixel XL using Tapatalk
Dimi Paralanov
flyinghorsemotorsport@gmail.com
1986 Porsche 944 3.0L 16V Conversion - on track duty!
1989 Porsche 944 $2 - for fun!
Old 02-24-2018, 09:00 AM
If you have the smaller diameter springs, CS springs for the 968 have the specs listed in the workshop manual.
Old 02-24-2018, 11:16 AM
With the turbo struts I have to use turbo springs as well?
Old 02-24-2018, 11:18 AM
Dimi 944's Avatar
Yes but you can use the Weltmeister or H&R lowering springs too
Dimi Paralanov
Old 02-24-2018, 11:20 AM
Great thanks!!
And strut mounts are all the same post 87 or something is that right?
So turbo Koni adjustables, my choice of turbo springs, and strut mounts and they will bolt right in? No other modifications?
Why did they make the S2 such an oddball with springs
Old 02-25-2018, 05:28 PM
Dimi 944's Avatar
That is correct. The difference is between ABS and non-ABS cars as the wiring coupler for the sensors are mounted on the strut. The smaller ID springs on the S2 and 968 we're introduced in order to accept wider rims/tires in 17" size without clearance issues.
Dimi Paralanov
Old 02-25-2018, 05:32 PM
So I might be able to grab these
Koni 8741 1136 r&l
Not sure how long they have been sitting around boxed up. Assuming they will work what's a good offer?
Old 02-27-2018, 09:04 AM
