930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
weltmeister springs ?
I'm getting conflicting information. whats top and bottom on these springs? do tighter coils go to top or bottom?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-27-2018, 05:48 PM
9FF 9FF is offline
Too Many Porsches
9FF's Avatar
They will work exactly the same regardless which way you fit them.
Mike A
Current: 1986 951; 1986 944; 1986 944 (Track); 2000 996 (Cab); 2005 CL55 AMG; 2009 GTS V8 (6-Speed).
Past: 1972 RS1600; 1983 E24 M 635 CSi; 1985 308QV; 1985 UR Quattro; 1986 944; 1989 M635 CSi; 1990 560 SEC AMG; 1994 E34 M5 (Track); 2001 461 Puch G; 2002 E46 ACS3; 2006 X308 XJR; 2010 LP560-4 Corsa.
Old 02-27-2018, 06:15 PM
^as a spring yes thats true.
however i believe the actual weltmeister springs are different end for end as far as physical fitment on the strut goes.
i had to put my 200# lowering weltmeister springs "tight coils down" - i had them the other way around for a while but got lots of clunking sounds. only flipping the springs made the noise go away.
though im sure someone else will come along saying they had to do the opposite..
and somebody may come along talking about the minutia of spring orientation vs unsprung weight...
Old 02-27-2018, 06:35 PM
Misunderstood User
I have Westminster springs on my 83 - pretty much plug in play.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 02-27-2018, 06:39 PM
9FF 9FF is offline
Too Many Porsches
9FF's Avatar
however i believe the actual weltmeister springs are different end for end as far as physical fitment on the strut goes....
So are they tapered like the turbo cup springs were? If they are then they will only fit one way. They must have changed the design or have a few different springs for the 944 as I had a set a long while back and they would fit both ways.
Mike A
Old 02-27-2018, 07:17 PM
dont think they're tapered, i think the "cut off wire ends" are slightly different angles or something.
maybe just my spring set though.
i've had mine since maybe 2007?
Old 02-27-2018, 07:28 PM
tighter coils on top is technically less unsprung weight
Old 02-28-2018, 03:04 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I bought variable rate (130/250) springs from QA1 and they aren't tapered. I'm using M30 adjustable koni struts and initially bought 10" springs that I hoped would allow me sufficient adjustment and yet lower the front end a bit. The results were it was too aggressive a drop (which would have been perfect for a track car) but mine ended up so low I couldn't even put the front splitter on without it dragging over the smallest bump. Plus I ran out of useable adjustment. I have now purchased a set of 12" springs (same specs) and will swap them out soon. I purchased them through Summit and the price and delivery was very good.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 02-28-2018, 06:12 AM
there we go..
Old 02-28-2018, 08:24 AM
