gt350mike's Avatar
Where to get a flywheel lock
I remember seeing a post where someone said you can get a flywheel lock for around $20-30. Anyone know where I can find one? While I'm asking about tools, any suggestions for a pin spanner (not sure what is the "proper" name) used to remove the rollers?
Thanks!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 02-19-2003, 07:29 PM
Scott R's Avatar
Depending on your time frame I could loan you my spanner and my flywheel lock.
But I can tell you that I found both on Ebay for about $40 total.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-19-2003, 07:37 PM
Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
The flywheel locks is to keep the engine at tdc ?
the prcie of a new one in diferent catalog are at $39.00
Old 02-19-2003, 07:46 PM
I'd recommend the factory one, I have and seen the aftermarkets used and they don't hold tdc, the factory one does, I couldn't believe that someone had difficulties copying it. You've got to turn the crank a little bit before or after tdc, not at it. Just my experience, and I'd doubt that all of the aftermarket ones are like the few I've seen.
Old 02-20-2003, 08:57 AM
