Trying to keep my 944 roadworthy
I had a clicking coming from the transmission. Pulled the trans; found I had a cracked Flexplate and two different size axles. I am in search of a Flexplate #944.421.121.00.
The axle I need is approx 22" long. Does anyone have these parts?
Thank you
Old 03-07-2018, 06:22 PM
Have 944, will restore
mazdaverx7's Avatar
It would help if you provided the year of your car.
85.5 944 Guards Red M456 5spd
06 BMW 330xi 6spd/ 92 Miata 5spd
04 RX-8 Nordic Green 6spd/ 01 MR2 Spyder 5spd
04 RX-8 Brilliant Black 6spd 86 Corvette 4+3
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
Old 03-08-2018, 02:39 AM
jhowell371's Avatar
Common fix is to replace the troublesome rubber dampener with a regular clutch disc and pressure plate. Do a search.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 03-09-2018, 04:31 AM
yes, you remove the auto flex plate (assuming you are referring to the rubber thing) at the engine-end and bolt on a good used manual flywheel, clutch disc and pressure plate.
no other clutch parts or pilot bearing required, all these parts serve to do is provide a solid connection between the crankshaft and the driveshaft.
and yes the automatic uses different-length axles.
Old 03-09-2018, 08:26 AM
jhowell371's Avatar
For parts try John Grimes at "Just Joshin Porsche 944 Parts"
301-992-1912 or www.porsche944usedparts.com
He's kept me on the road for years.
Old 03-10-2018, 04:04 AM
