Same insert came loose on an 87 944. We just epoxied it back in place and it's been racing in 944 Spec for yrs.
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 04-01-2018, 04:55 PM
Diving in 911
Thatís the kind of results I like to hear!
Old 04-01-2018, 09:14 PM
Wow...
I just got an '84 944 for my son and we are currently working through some issues. Found Bad fuel pump, vacuum lines, TPS and now injectors.
But all that was easy. My biggest hurdle right now is pulling that damn strainer. It's like welded on! The only reason I was trying to pull it is because of all the other related fueling issue I have and figured it would be a good thing to service. But I don't want to "break" it or the tank trying to remove it.
At this point, I feel it best to just leave it alone....but i dunno.
Old 08-02-2018, 06:20 PM
Diving in 911
Mine was covered in sludge and the strainer basket / screen was falling apart. You could put a solvent in there and let it marinade for a bit then flush. You can also check the fuel flow rate to see if it’s an issue. If I pull one again, I’m going to soak it in PB Blaster, tap it around the filter to wake up the threads, maybe do that 3-4 days in a row. I would also put a band clamp around the spigot. Mine appears to be holding fine.
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1987 951 Turbo
1981 928 blk/blk 5sp
Old 08-02-2018, 07:59 PM
