Diving in 911
Fuel tank outlet pulled out...
So I twisted out the fuel tank outlet (threaded insert the strainer screws into). Search and couldnít find anything here. Someone has to have had this issue before? Thinking some sort of epoxy, maybe JB weld, to get the insert set. Anyone had any experience with this? Have the strainer and insert marinading in PB now, will separate the two on the bench. Thanks.
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1987 951 Turbo
1981 928 blk/blk 5sp
Old 03-07-2018, 10:09 PM
Patrick
pfarah's Avatar
It's called SOL...!
Happened to me which resulted in restoring a spare tank I had laying around the shed.
1984 944 NA, constant tinkering
Old 03-08-2018, 05:17 PM
Diving in 911
Not what I wanted to hear...lol
Lol! Not giving up yet. Think I have a plan. Have it all apart, picked up a new strainer from the dealer today. Filed the insert edge hoping to get it back in the bung...no luck. Iím going to use a rotary tool with a diamond cutter to notch around the inserts leading edge, just enough to get it started in the hole. After itís started, Iíll line the inside witha nice smear of marine JB weld using my finger through the insert. I ripped the filter out of the old strainer and will use it to drive the insert back to the correct depth. After I reach the scored part of the insert I will put a swirling bead of JB around it to carry the material in as itís inserted.. after the right depth for the insert has been achieved Iíll back the dummy strainer off and use a thin rope of JB putty (think pencil lead) to fill the space between the insert and the tank. Also going to put a hose clamp on the outside of the inlet.
All this being said.....one of my local PCar buddies has another tank....so if Iím not getting the results I want I can JB the shat out of the outside of the mating surface and just plane on tank replacement the next time the transaxle has to come out.
Iíll post some pics and results I got...
1987 951 Turbo
Old 03-08-2018, 05:50 PM
Diving in 911
Back in...
So I thought I would give a little update. I used a triangle file to notch the threaded insert and needle nose to turn the teeth in slightly ....gooped the inside of the tank outlet with JB marine then drove the insert through hole with a piece of scrap wood and a 5lb mallet. When it was in up to the scored area I smeared JB on it before driving it to depth. It is in their TIGHT. Even with the 5 pounder it took some good wacky to get it in there. It naturally got a nice bead through each of the register holes just past the threads as well. I used the excess to make a nice smooth bead between the insert and the tank as well. I cleaned everything really well with alcohol before I got started.
More to follow.....
1987 951 Turbo
Old 03-13-2018, 01:31 AM
Diving in 911
More pics..
Here itís in. Going to let it set up for a couple days as itís pretty cool here still
1987 951 Turbo
Old 03-13-2018, 01:33 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
I hope for your sake that JB Weld Marine is resistant to Ethanol.
I sealed up my tank with an Aircraft Tank Sealant, a grey rubbery stuff, and very expensive in the UK, but probably much less pricey in the US where it came from.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear swaybar.
Ford Focus 1.8TDCi estate daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 03-13-2018, 03:25 AM
I am very concerned we will run into the same issue on my sons car.
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 03-14-2018, 05:22 PM
Diving in 911
I could have likely avoided this...
Unless you have already spun the insert you might be OK. Going back, I would have marinaded the filter rim in PB blaster then ďwakeĒ it up with some taps around the perimeter with a hammer. It took some pretty good force with the 17mm socket to spin it. As you can see in the pics itís pretty well molded into the tank bung. It took some muscle to get it out the rest of the way after I realized what I had done,...and what I needed to do to fix it (hopefully)......Now you may ask ďwhy would someone force it to the point of spinning the insertĒ?... and that would be a great question that I wish I could answer for you. :-/
1987 951 Turbo
Old 03-14-2018, 05:43 PM
Ours is leaking a bit must be an o ring? But thats because it sat dry for 10 years..
Ben
Old 03-14-2018, 05:50 PM
Diving in 911
Mine sat for 10 years as well. The O ring was pretty well cracked.
1987 951 Turbo
Old 03-14-2018, 06:14 PM
CBerry
Nice work around!!! Well done!
Old 03-14-2018, 07:29 PM
You can get a hose clamp around this neck to hold the insert to the tank before you pull the tank strainer to prevent the problem. It might also help seal a loose insert.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 03-15-2018, 04:33 AM
Just so you know - this is GREAT!
as someone who can't really tell if his sort of mental illness / habit of dumping his pictures of 944 work on Pelican helps anyone or just makes me look like a lunatic...
87 944 NA
Old 03-17-2018, 06:42 AM
Well tonight we did the same thing.. Gotta get the screen insert off and clean of the the threaded insert and jb weld I guess..
Ben
Old 03-18-2018, 06:15 PM
My fitting was trashed so now gotta figure out a solution.
Ben
Old 03-21-2018, 04:34 PM
Diving in 911
If you have the tools you could buy a piece of aluminum pipe, cut to length, tap the inside, score the outside and drive it in. You could make a bunch more registry holes in it as well to help lock it in place. A slightly larger OD would help with the seal. The tank is actually rather flexible which was a surprise. You could also plasti-weld a cap on the end with a bung in it, then use an inline filter. The only issue is the space under the cover. The quick elbow would have to be turned into a bigger loop to accommodate the inline without getting a kink.
1987 951 Turbo
Old 03-25-2018, 09:37 PM
Diving in 911
Auto OCD
I know what itís like to hope for the pics to connect the dots in my head! LOL
1987 951 Turbo
Old 03-25-2018, 09:46 PM
The problem is its 37x1.5 mm which i am yet to see a tap for sale in that size.
Ben
Old 03-26-2018, 04:35 AM
Diving in 911
Tap
That would be an issue. Got mine back together last night. Have to clean the lines, wp, belts, hoses etc now before I get to the fuel in tank stage. Having sat for 10 years, this was likely not my last ďshore excursionĒ on this journey.
1987 951 Turbo
Old 03-30-2018, 01:40 PM
Diving in 911
....we shall see
So here we are...
1987 951 Turbo
Old 03-30-2018, 01:44 PM
