need some wiring help
Looking to put a 944 turbo engine into a 1990 S2 convertible. Has anyone done such a conversion before? Any ideas on how to wire 944 turbo engine harness into S2 chassis at drivers fender connection? Thank you in advance for your help.
Brian944Turbo has done this several times....
I just recently put an 89 turbo into my 83 track car. I used an AllData wiring diagram and the following pic. You won't have the same issues I did as I had to go from a 9 gang connector (83) to a 14 gang connector (89) to tie the engine harness into the body harness. You should have the 14 gang already. You'll also have to get the auxiliary turbo water pump and relay, if you want them. Pretty easy to add the relay into the wiring as it is separate from the engine harness. Of course there's quite a bit more that ultimately goes into it, but the wiring isn't too bad.
http://forums.pelicanparts.com/uploa...1520664792.jpg |
thank you for oyur help guys
| All times are GMT -8. The time now is 09:40 PM. |
