Thanks. I have the kit ordered. Will be tackling this week..
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 06-11-2018, 04:10 PM
One apex at a time
Dean924s's Avatar
Stop!!!!!!! Do a timing belt NOW. 10 years is way past due. It is a matter of when not if it is going to fail.
Old 06-12-2018, 05:46 PM
Umm my last post "kit ordered"
Its here and gonna look at it this week.
Ben
Old 06-12-2018, 06:05 PM
Ben,
If you don't know the history of the fuel lines in the engine bay, I suggest you replace them asap. The two over the exhaust manifold have charbroiled too many 944's. They may look OK outside, but they deteriorate from the inside. There us also a small one on the fuel rail.
Have fun with the project, you and you son will love the car!
Bruce P.
1988 951 Alpine White, AutoAuthority chip, HRE custom wheels, 10 speaker panels, Schnell short shifter, M030 sways, Koni Sports
"You're the best I ever had" --JJ Cale
Old 06-12-2018, 07:08 PM
Originally Posted by Ga 951 View Post
Ben,
Ok thank you. Can I just replace the rubber portion with bulk fuel injection hose?
Ben
Old 06-12-2018, 07:33 PM
Some phone dial love..
Ben
Old 06-13-2018, 12:35 PM
Unfortunately, both fuel lines are hard from the tank area to the right front wheel well. The easiest way is to take the liner off and cut the hard lines, then I used a compression fitting the fit the rubber line. You may be able to take the damper line to a hyd hose shop and have them use the fitting with new hose. I just bought a kit online that had everything needed. Should cost ~$100 for the press and return line. The little one on the fuel rail has a unique fitting as well...another 100 ish.
Sorry for the unwelcome news.
Love the wheels...will look nice on the white
Bruce P.
Old 06-13-2018, 06:58 PM
Timing belt is done along with cam box gasket.. Still need to look at the fuel line but in due time.. Currently not driving the car.. He took the fenders and bumpers off and sanded it and today I showed him how to prime. So all the sanded parts are epoxy primed now to do body work..
Ben
Old 07-22-2018, 01:11 PM
Awesome...!
This is how I got my son started.
Painted his entire 1st 944S himself.
T
Old 07-24-2018, 06:18 PM
