Piecing together a timing belt kit
I own a 1984 944. Has the updated water pump.
I am looking to change the belts, rollers, water pump and all seals.
Since I have an updated water pump, am I correct in ordering the late timing belt kit?
Here are the part links that I am thinking of ordering:
https://944online.com/index.php/new-944-water-pump-kit-83-88-2-5-stage-2.html
I found a seal set at zims, with the following description:
14 piece kit includes:
1 cam seal
1 cam o-ring
1 distributor housing to cam housing seal
2 balance shaft seals
2 balance shaft housing o-rings
1 front cranshaft seal
1 front crankshaft o-ring
3 mylar washers
Fits:
1983- mid 84 models
up to-eng
43E14858
43E21783,
the engine seals, says it's for 83-84 mid models. I think that it should say 83-85.5? This is the seal kit that I need to order?
Is there anything else that I am forgetting? This seems to be a cheaper way than ordering a kit from ECS for $500+
Old 03-10-2018, 03:31 PM
forget about model years and engine numbers.
if you have the updated water pump (with the shiny belt guard bar thing, pictured on your 944 online link), then you use the -86 type belt kit with a 46mm black plastic with red/orange bearing timing belt idler.
Old 03-10-2018, 03:53 PM
Coeur d'Alene, Idaho
Hmm. The linked kit does not have any seals. I nosed around a bit and could not find a "14 piece kit". So I'm not really clear on which kit you are asking about. However, I will say that since buying my 944, Pelican has been an amazing, accurate and consistent resource in buying parts for my 1984 non turbo 944. Today was a perfect example. I ordered a clutch slave they said would be here Monday. However it showed up today, meaning I can install it tomorrow (Sunday) and be able to drive it Sunday afternoon as it will be unseasonably warm. Pretty cool.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 03-10-2018, 11:15 PM
What about the balance shaft races? I understand replacing balance shaft seals alone doesn't always fix things.
Old 03-11-2018, 05:37 AM
I happen to be into a similar project myself, mainly to cure an oil leak. The belts, rollers, seals and races are relatively recent (30k miles) so something didn't last as expected, either the crank or the balance seals went bad. Any opinions?
Old 03-11-2018, 01:14 PM
that much oil, everywhere makes me think your oil pan gasket is tired rather than a front seal.
Old 03-11-2018, 01:47 PM
Lovely, the oil has crawled all the way up the front of the engine. What is the fix, does it involve dropping the cross member?
Old 03-11-2018, 01:56 PM
Well after doing some cleanup and disassembly, I think it is the cam seal. Oil is running down the front of the engine and going everywhere. Is there anything else in the area it might be? The cam tower gasket is fairly fresh, is there a gasket behind the distributor housing?.
Old 03-18-2018, 08:33 AM
distributor cap has a foam dust-gasket.
then theres an o ring and a rubber bushing between cam gear housing and cam housing...and a radial seal behind the camshaft gear
Old 03-18-2018, 08:57 AM
What about a race? Also what size is the cam cheesehead bolt and where is it sold?
Old 03-18-2018, 10:28 AM
you can get a tool for the cheesehead on the shelf at your local auto store, a set of 3 or 4 sizes for $8 or so, triplesquare usually called.
i think the one for the cam is 10 or 12mm.
race is between the camshaft and the radial seal
Old 03-18-2018, 05:14 PM
Just finishing up a front reseal, belts, and water pump. I called Ian instead of placing the order online. He was extremely helpful on getting me everything I needed. All the parts came bagged and marked where they go. I can't recomend them highly enough.
Also, if you are going to do the cam seal, order the offset cam key. You have everything off to do the job. Other than a little filing on the key to get it to fit right, there is no extra work.
And one other thing: If you strip the cheese head bolt it is easy do drill out the head as stated in other posts. Took maybe five minutes.
Old 03-21-2018, 04:52 AM
I discovered a really easy way to get the cam bolt out. Instead of struggling with a 2nd wrench to hold the cam, just put a drill bit or screw driver through the screw hole at about 2 o'clock. It lines up perfectly with the cam gear teeth and will lock the cam gear in place for loosening the cheesehead bolt.
Old 03-24-2018, 05:21 PM
