Lightbulb 944S surprize
Unbelievable, I bought a 1988 944s that the tensioner had failed, as a project. I pulled the Head today and not one valve is bent.
Now if I can get the Head repaired where it cracked, and find a set of cams, and get a new tensioner.
88 944s
Turbo front clip
Side markers and rear bumper pads deleted
93 968 interior.
Old 02-21-2003, 07:57 PM
ae1969's Avatar
Send a message via ICQ to ae1969
1. take that head to machine shop that is familiar with 944 heads
2. Unless someone has had the valves out and checked these valves...don't consider yourself lucky just yet.
3. Have your guides checked/replaced if necessary
4. All valve seals need to be replaced.
5. If the head was cracked due to the tensioner failing....99% you bent a valve.
6. S heads are not cheap.... but depending on how bad the crack is you may be able to have it repaired....
Sorry I don't sound encouraging....but an S heads that fails is not a happy event.
Good luck!
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-21-2003, 08:34 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Welcome to the world of it "S"....or "S"H!T my head is smashed again!!!!
180hp is nice though...-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 02-22-2003, 02:23 AM
Good luck!
I appreciate the guidance. I know that whatever happens it is not going to be cheap. I just thought that after hearing about valves always being bent , and being a technician I have seen some catastrophic valve damage, that these do not appear to be.
Does anyone know of a machine shop in the atlanta GA area familiar with 944 engines?
88 944s
Turbo front clip
93 968 interior.
Old 02-22-2003, 05:48 AM
