Replacement Carpet Questions...
I am looking to swap out my beige carpet set for a black set but cannot find a good used one anywhere. First off, I want to buy one so if anyone has one I am a buyer. If not, anyone know a good quality aftermarket supplier? I would want as close to OEM as possible but so far have come up empty. This is for my 968 so not sure if a 944 set works or not either.
I have one for sale in the 944 section. It’s a black appbiz carpet . I had it for about six months and wrecked the car. I have all the pieces and they are labeled.
78 911 st backdate 87 944 00 996 |
Guess I should have read your post better. Saw you need it for a 968 mine is for 944. Not sure if they’re the same.
Neither am I. And the earlier 944's had a different carpet material than later ones. Which do you have?
Diving in 911
Call Appbiz. He makes great quality stuff. I have their 911 RS kit and called about 944 carpet...he didn’t do linen though. If you look at the PET for the 968 it will likely be a 944 part number for the carpet. Worth checking though.
1976 911s Special Edition Turbo bodied IROC tribute 2002 911 Carrera C4S 1971 914 1.7 Tangerine 1989 964 Coupe/1992 964 Cab 1987 928s4 Granite Green / 1986 951 |
I have the lightweight perlon I believe. I’ll have to find the receipt.
My question with Appbiz is whether it is molded and has the right amount of sound deadening material. I read that it is a little thin.
