West Central Ohio 45380
Oil smells like gas
So my sons turbo has been a year since it’s oil change. His oil pressure has been dropping a little low so we changed the oil. The oil was thin and smelled of fuel. What are your thoughts guys?
www.plyhammersparts.com |
check the control line for the pressure regulator and/or the leak down on the injectors.
try to run 100% gasoline. I get corn-free 93 at the local Co-op...and 10% better fuel economy. |
Mine did this as well. It ended up being a bad ECU making it run rich. Rebuilt ECU and issue solved.
Sent from my iPhone using Tapatalk |
