Angry Knockng noise from rear
Can anyone help!!!
There seems to be a knocking noise from the rear of the car, at first i thought it might be the CV joint. However it still might be.
But when your driving it comes and goes, but when you dip the clutch it goes.
Has anyone had this problem.
Sometimes it gets really bad, and then disappears, its very intermitent . I have had it up on a ramp and moved the joint, which has stopped the noise but i know its going to come back.
Help
Kind Regards
Sanjit Aujla
Old 02-25-2003, 07:43 AM
AFJuvat's Avatar
Sounds like you are due for CV replacement.
I would pull and replace them.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-25-2003, 09:00 AM
Razor944's Avatar
Send a message via AIM to Razor944
Does your car seem to make the noise more on acceleration and deceleration.. or just when your cruising? I had a problem where there was a loud clank noise in my rearend when i acclerated and decelerated and it was because the rubber hub on my clutch was shot (here is the pic www.homebuiltjeep.com/clank.jpg). Let us know when it makes the sound and what it sounds like.
Old 02-25-2003, 10:47 AM
Roger Hall's Avatar
I heard a noise and I swore it came from the right rear wheel. Couple of weeks and $350 dollars later I had new rear axels and CV jount's. The noise did not go away. It turned out to be the clutch. CV joint replacment was not a bad idea they were showing some wear, but I could have used the extra cash for the clutch job.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 02-25-2003, 05:31 PM
Razor944's Avatar
yah that was my problem as well. i bought a new sachs clutch kit for 510 dollars. if you do it yourself be careful when taking the belhousing off not to break the sensors.. it was a 140 dollar mistake for me
Old 02-25-2003, 09:25 PM
J1NX3D's Avatar
hmmm... im getting a regular clunking sound from the rear right in my auto 924 under braking. i can feel it thru the pedal. i pulled the drum off on that side and saw nothing peculiar
any suggestions?
'86 944S3 conversion
Old 02-25-2003, 10:08 PM
Razor944's Avatar
just braking? what about accelerating hard?
Old 02-25-2003, 10:13 PM
Bay Area Patriot
TheStig's Avatar
Sanjit try this....drive your car in second gear, slowly ease off the gas and then slowly reapply it. If your car jerks and stumbles and a noise is from the rear, the rubber hub on your clutch is shot. Mine just went out 3 weeks ago and it made the same noise. The noise from the rear of the car is because the hub that separated and the disc are spinning at different velocities and are striking eachother, causing the power in the rear end to decrease and increase intermittenly...in short, give you a real jerk in the seat of the pants
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 02-25-2003, 10:35 PM
J1NX3D's Avatar
nope, just braking. doesnt matter if im turning either, just while braking
Old 02-26-2003, 01:30 PM
Roger Hall's Avatar
Does your 78 have 4 wheel disk brakes? I have heard that if the backing plates are missing it will cause a clunking sound. From the rear is strange though. The rear brakes do alot less braking than the fronts.
Roger Hall
81 924 N/A
Old 02-26-2003, 03:18 PM
J1NX3D's Avatar
nope drums. im getting new drums and the shoes relined soon so i'll get a brake/ suspension specialist to check it when i get the shoes relined.
Old 02-26-2003, 04:11 PM
Roger Hall's Avatar
sorry I dont have any idea. Never had to fix that type of issue.
Roger Hall
81 924 N/A
Old 02-26-2003, 05:39 PM
