coupe's Avatar
Tyres. approved by Porsche??
I was talking with someone today about tyres for my 944, and this guy, also a 944 owner advised me to get tyres with letter codes N0, or N1 or N2 or N3.
He said that every company makes some model tyres as per Porsches' specification.
Can anyone outhere shed more light on this subject?
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 02-27-2003, 11:30 AM
Ornery Bastard
As long as you get a name brand tire with the appropriate speed rating, you're fine. I wouldn't recommend anything less than an "H" rated tire though.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 02-27-2003, 11:33 AM
PorscheG96's Avatar
Send a message via AIM to PorscheG96
The sidewall construction of n-rated tires is slightly different than the regular stuff each manufacturer puts out. These cars just feel more stable at high speed with n-rated tires, but you shouldn't mix/match the n-ratings. n0 was the first rating, very good in the dry. n1 tires got better tread wear, n2 was improved for wet weather, and n3 I'm sure was improved some more but I forget how. My n0 tires were scary in the rain and lasted like 8k miles. I haven't bought n-rated tires since.
Old 02-27-2003, 12:32 PM
coupe's Avatar
PorscheG96, thanks for shedding some light on this subject, and I sure can understand why you no longer bought N rated tyres. I guess Pirelli P7000 with a R speed rating will do me just fine.
Thanks again
coupe
Old 02-27-2003, 12:41 PM
stray15's Avatar
Send a message via AIM to stray15
Pirelli is Porsches OE tire company now, last I heard.
Aaron, Porsche doesn't recommened anything less than a V.
Old 02-27-2003, 12:43 PM
Ornery Bastard
You try finding a 195/65 R15 tire in a V rating.
I've got a set of H rated Bridgestone Potenza RE 950s on my 924S right now and they've been great for all-season driving. True the tires aren't rated for above 130 mph (H=130, V=149) but I'm never going to be going any faster than 85 or so if I'm in Michigan.
Would a V-rated tire be better in the summer? Sure. But I doubt that there are very many V-rated tires that could have handled the snow we got in Pittsburgh last week.
It's a trade-off. An H rated tire will perform just fine for on-road driving. Unless you're very agressive a V rated tire isn't a necessity.
Aaron
Old 02-27-2003, 12:51 PM
coupe's Avatar
Well, I tyre that holds up well in a hot and humid climate. I tyre that will not get a flat spot if it sits for a couple of weeks at a time.
Pirelli P7000 are available at a good price from the main tyre dealer, and they were manufatured last year.
I may be getting a set of these, as soon as I get the water pump, timing belts done.
coupe
Old 02-27-2003, 01:11 PM
stray15's Avatar
Aaron
Yup, not a fun tire size. Just off the top of my head, in that size I believe Michelin has the MXV4 +'s, Pilot Primacy, Yokahoma AVS db, Kuhmo Ecstra (really cheap usually), Pirelli has a few, not sure of the model and I believe Dunlop does as well. Just to throw some examples at you.
Also, when you have a car that the manufacture says not to go under a certain speed rating, you will lose some of the handling characterists and you will increase braking distance. The speed rating isn't just about how fast you can go without the tire exploding. Thats a typical misconception.
I know exactly what a Porsche feels like with the incorrect speed rated tires. I unfortantly don't practice what I preach. I don't have the money for tires and I don't plan on keeping the car long so I don't want to waste the money.
Again, if money is an issue, then you may as well go with an H-rated tire. But if you have the extra doe I wouldn't cut corners.
Coupe, what size are you looking for?
Old 02-27-2003, 05:04 PM
Ornery Bastard
Yeah, I know that there are V rated tires available in 195/65 R15, but when one needs tires immediately (blowout) it's almost impossible to find a shop that has name-brand V rated tires of that size in stock.
Honestly, the H rated RE950s feel a lot better than the tires that were on the car.
I understand that the "speed rating" is also related to sidewall strength and not just to heat capabilities. I also realise that a lower-rated tire will flex more under breaking and cornering, and that handling will be sub-optimal. Still, the car is leaps and bounds above the capabilities of my last car, and I doubt that I'll ever excede the capabilities of the tires I have on the car.
Aaron
Old 02-27-2003, 07:07 PM
stray15's Avatar
Aaron
Old 02-27-2003, 07:54 PM
who currently produces "N" rated tires, and what products do they have?
Old 02-27-2003, 08:12 PM
coupe's Avatar
Makers of N rated tyres
Here are some N rated tyres. Source: Porsche excellence magazine.
Bridgestone Expedia S-01
205/50ZR-17 N-0
Potenza S-02
205/55ZR-16 N-3
These are available in various sizes.
Continental,Dunlop,Michelin,Pirelli and Yokohama also make them in N rating and in various sizes.
coupe
Old 02-28-2003, 12:23 AM
