Bob's944's Avatar
Send a message via AIM to Bob's944
Unhappy Power Steering Leak
Just got out from under the car, the power steering rack is leaking from around the boots, mostly on the passenger side. Pump is working ok, no noise... I am able to keep up with the leak by adding fluid every few times i take it out. What are my options to fix it?
Old 02-27-2003, 04:23 PM
I had the same problem, get under the car and look from the front end on the passenger side to the right of the tie rod boot, there is an allen bolt, check to see if its leaking around there, if it is, it will leak all over the steering rack around the boot on the passenger side. Dry it completely off, i mean completely, i washed it off with a hose and dryed it, then start the car and move the wheel back and forth a few times, shut it off, get under the car right away, and watch for leaks. You will find out where the leak is coming from, hopefully its coming from the allen bolt like mine was, all i did was put in 2 new and a little thicker O-Rings, which sealed it good and doesnt leak anymore. Good luck, hope this helped some!
-John
Old 02-27-2003, 04:29 PM
