Rod bearings
Porsche 928 s2
When doing rod bearings do you need to change bolt and nut.or just nut
Old 07-30-2018, 11:58 AM
stepson's Avatar
Originally Posted by porschedavid View Post
Porsche 928 s2
Nut.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 07-30-2018, 04:26 PM
Petie3rd
Mrmerlin's Avatar
the rod nut has a serrated mating surface ,
This surface will deform into the rod cap,
this will give the nut extra mechanical grip once its properly torqued.
Removing the nut and installing again will put a worn serrated surface onto the cap ,
the grip that a used nut has will be less than a new part.
Do you want your worn nuts to come loose at 6500 RPM
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 07-30-2018, 05:30 PM
So i dont need to change the rod bolt like you do on 1984 Porsche 911 3.2 carrrera air cooled
Old 07-31-2018, 03:07 AM
