Rear quarter glass
How do you removal the rear quarter glass so i can treat the rust without breaking glass or damaging the rubber seal
Old 08-06-2018, 11:55 AM
JK McDonald's Avatar
Rear Quarter Glass -
Hey Dave- The only time I've seen the Rear Quarter Glass removed was during a complete repaint in a body shop. A couple of tech's used a super thin steel wire stretched between two "T" style handles to carefully saw through each rubber seal. Once the body work and paint was complete - New seals were used to install the windshield, quarter and rear deck glass.
With the age of our 928's I don't know if trying to reuse the old seals would be recommended or even possible.
Good Luck -Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 08-06-2018, 03:01 PM
stepson's Avatar
It's doable. The main thing is breaking loose the seal between the glass and the rubber and the car body.
You have to remove the outer trim being very careful not to bend the trim. I used plastic utensils to make sure I didn't damage either the glass or the rubber.
Once I got it broken free most of the way around inside and out, I pushed the glass toward the outside and used plastic pieces to hold it out and just worked my way around a little bit at a time until it was completely free across on flat side. You can then move the glass around a bit and work it out. You can push pretty hard on the glass. It's pretty tough.
It's a real good job to find out who your friends are because multiple hands are greatly appreciated.
The other way to do it is to break out the glass and just replace the glass. The seal costs way more than the glass if you can even get one.
But that's not the way I roll.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-06-2018, 05:07 PM
Network Native
Danglerb's Avatar
Usually its pick one, seal or glass, but unless the seal is impossible to get I would replace it.
Old 09-19-2018, 11:34 PM
Quarter Glass Removal
There is a video clip of the quarter glass removal on youtube. I tried to attach, without any luck.
Old 09-20-2018, 06:19 AM
SharkHead
JhwShark's Avatar
928 Intl had the seals (used) in the past...I picked up a pair as mine were very degraded. I still have the work to do...
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 09-20-2018, 01:49 PM
stepson's Avatar
I think this is the youtube link:
https://www.youtube.com/watch?v=_TM6GZWQZFg
Old 09-20-2018, 02:48 PM
got them out quite easy without cutting rubber or breaking glass
Old 09-21-2018, 05:53 AM
stepson's Avatar
Excellent!!
Old 09-21-2018, 10:39 AM
Rear Glass Install -
Hey Dave - After watching Stepson's U-Tube video on the installation of the rear quarter glass panel a few times I think the guys I'd seen removing my buddy's glass from his 928 a few years ago were ideots. They had already cracked the corner of his windshield. Although this high end foreign car body shop had a large 928 GT banner in their waiting room at least some of their tech's were obviously not 928 qualified.
The small drain holes shown drilled through the lower edge of the window frame in the video sounds like a good idea. Especially since they are under the outer edge of the rubber seal and not visible once everything is in place. Good Luck with your install -
Michael
Old 09-21-2018, 11:35 AM
stepson's Avatar
Michael,
I can't take credit for any part or anything regarding that video other than I found it and posted it here for you guys.
Old 09-21-2018, 04:54 PM
