1981 928 vaccum lines diagram
In the process of replacing the green wire i've broken several vacuum lines/ Looking at the diagram under the hood the vacuum lines goto the throttle valve housing and using a tee to the "thermostatic valve in cooling liquid circulation" and the throttle valve housing. I assume the 2 distributor vacuum lines attach to upper and lower port on the throttle valve housing however I have no idea where the thermostatic valve in cooling liquid circulation is
Old 08-29-2018, 06:07 PM
honerboys's Avatar
my 84 has almost the same diagram under the hood - but i looked and i can't seem to find that thermostatic valve either - maybe location specific?
84 928 S
Old 08-31-2018, 08:19 AM
SharkHead
JhwShark's Avatar
I believe it is along the firewall behind the engine.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 09-25-2018, 01:35 PM
