944paige
Send a message via Yahoo to 911paige
928 wheels
Hi I have a set of 928 wheels that I purchased for my 944, they are the standard stock wheel my Question is I donít have the 944 any longer and would like to know if I can use these wheels for my 1992 300ce Mercedes Benz. Any help would be appreciated Iím not sure if they will fit Iím aware the bolt pattern may be different.
Old 09-11-2018, 08:40 AM
George928's Avatar
Originally Posted by 911paige View Post
Hi I have a set of 928 wheels that I purchased for my 944, they are the standard stock wheel my Question is I don’t have the 944 any longer and would like to know if I can use these wheels for my 1992 300ce Mercedes Benz. Any help would be appreciated I’m not sure if they will fit I’m aware the bolt pattern may be different.
928 bolt pattern is 5x130.
1992 Mercedes Benz 300CE (24-valve)
5x112
Old 09-12-2018, 11:28 AM
944paige
Looks like they wonít fit, I wonder if the make spacers to allow them to fit?
Old 09-12-2018, 04:42 PM
Look for H&R wheel adapters that convert 5x112 to 5x130 bolt pattern. I am currently running a set of Porsche 928 7-slot/disc wheel on my '97 Saab 900. I found a set of H&R adapters (high quality made in Germany!) to convert 5x110 to 5x130. The adapters were about 20-25mm thick. The high-offset of the 928 wheels makes them perfect for use with adapters on other cars, as the adapters will fit without making the wheels poke out too far. In my case, the adapters made up the difference in offset between the stock Saab wheels and the 928 wheels, so I'm only off by 4mm from stock! I recommend using an offset calculator like https://www.1010tires.com/Tools/Wheel-Offset-Calculator to calculate whether or not the 928 wheels will fit properly on your Mercedes once you find proper adapters.
1974 911 (non-running)
1978 928 5-speed "hillclimb special" (work in progress)
1983 944 5-speed, Guards Red
1984 928S 5-spd, Schieferblaumetallic
1997 Saab 900, Scarabe Green (5-speed manual conversion, Trionic 5 turbo conversion)
Old 09-13-2018, 04:29 AM
944paige
Wow thanks for the info, since I have the wheels with good tires and I need tires on the merc, maybe it will work with spacers and cost less than 4 new tires. Thanks I will look into that.
Old 09-17-2018, 06:39 PM
