1983 928 camshaft position
Hello,
I am almost done doing the Timing Belt on the 1983 928 Porsche. I reinstalled the camshaft pulley and the tooth is not aligned as per the picture.
Am I able to adjust the cam at this point by turning it to align as needed? Any risk at this level. Please note the main cam is locked.
Old 08-07-2019, 04:18 PM
stepson's Avatar
You can turn your cam without fear of damage if you use the large hexagonal washer under the 17mm bolt head holding the cam gear to turn it.
Your engine should be non-interference.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-07-2019, 10:30 PM
Thanks Stepson
Old 08-07-2019, 11:00 PM
