Tim Boyer's Avatar
Sunroof question
Hi,
Is there a way to manually open/close a sunroof. It is clear that I have to take apart the system if I want the sunroof to work. However, it is slightly open and that poses a problem since the car is kept outside. Any thoughts?
Thanks,
Tim
Old 11-30-2019, 03:36 PM
ptrsbtrs
peter leinberge's Avatar
It will require either a flat blade screwdriver or an Allen wrench (usually)
There might be a plug in the headliner or a zipper in the rear (usually)
or you might have to remove the front map/interior light assembly, I haven't done a 928 for years
Or if the entire unit is frozen in place, you can pull the headliner panel down from the front leading edge, release the cables and slide the panel forward to the closed position.
Old 11-30-2019, 08:10 PM
honerboys's Avatar
hey tim - if you pull the sunroof motor cover off i think you can spin the rubber motor coupling by hand - if the cables are intact it should slide close - but as peter stated above if it's all seized up more disassembly will be required
84 928 S - SOLD
2012 Cayenne S
Old 12-01-2019, 03:55 PM
Tim Boyer's Avatar
Thanks!
Old 12-01-2019, 06:51 PM
