928-recent virgin
79 fuel sending unit
does anyone know how long the fuel sending unit is for the 79 model? Thank You.
1986 928s black on black 1971 Ford Mustang Conv |
Fuel Gauge Sending Unit -
Hey Luke - Are you having problems with the fuel gauge circuit or are you needing to replace the sending unit ? Most of them were a standard size. I'd read one time that there was an optional "over sized' or touring gas tank available in some countries. I assume that the one for these tanks would be different.
The sending unit can easily be repaired if not too rusty and the only problem is that the thin sliding wire loop has broken. Good Luck - Michael
1984 928S - "Miss Purdy" 1987 911SC - "Frau Helga" 1986 930 - "Well Hung" 1975 911 Targa "Blue" |
928-recent virgin
Thank You
I cleaned the sending unit in my GT with a scotchbrite pad on the tube that the float slides on to clean the built-up debris off and make it smooth again. I was very careful to stay away from the wires to avoid damage there.
Reinstalled sender unit with a new gasket/seal and it works perfectly.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
