luthir2's Avatar
Send a message via MSN to luthir2 Send a message via Skype™ to luthir2
Fuel Tank Difference?
Was the fuel tank always the same?
1980 928 S Euro
1987 928 S4
1986 944 N/A
2001 Boxster S
2000 996 Cabrio
Old 02-27-2020, 02:01 PM
stepson's Avatar
Yes regarding shape.
The very early cars had a smaller fuel strainer opening
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 02-28-2020, 06:44 AM
luthir2's Avatar
Thank you Stepson, any issues using a tank from an 87 s4 in an 80 S Row? Seems it should be OK if its is just the strainer opening?
1980 928 S Euro
1987 928 S4
1986 944 N/A
2001 Boxster S
2000 996 Cabrio
Old 02-29-2020, 02:50 PM
stepson's Avatar
I believe the 80 model tank may be missing the tab above the filler neck that includes the mounting bolt. That said, you may just have a fuel tank that has a tab above the fuel neck that has no mounting bolt in it. Shouldn't be a big deal since the shape and fit are basically the same.
Old 02-29-2020, 07:34 PM
As the prior few posts mentioned, the earliest (early 78 only?) cars did have a smaller tank outlet, and the later cars added the tank support hook, though some have complained about those being rusted off.
My '78 has a tank from a much later car installed, and other than the extra mounting tab at the top of the filler neck, it's much the same as any other tank.
It came to me with a broken fuel pump bung in the tank outlet, which I replaced with a strainer basket since I already had two external pumps on my car.
Old 03-04-2020, 11:49 AM
Network Native
Danglerb's Avatar
If you are thinking about a used tank, check the production date molded into the tank. Lots of early tanks ended up in newer cars, so a tank from an S4, could have spent a dozen years first in a early car.
Old 03-07-2020, 08:07 PM
My Euro 84MY's tank cradle was very rusty, so replaced it with a second hand S4 one. It fitted but only after some home modification.
Old 04-14-2020, 02:53 PM
