-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Dynomat (http://forums.pelicanparts.com/porsche-928-technical-forum/1070956-dynomat.html)
manuyc 08-22-2020 05:14 AM
Dynomat
Gm everyone!
Im planning to dynomat the interior of the car after the P.O.R was done.
the question:
1. Should I dynomat the door panel?
2. if i do will the door card stick out more?
Danglerb 08-23-2020 05:10 PM
I would only do the inside of the door with the dynomat, the card side maybe a heavy plastic sheet stuck to the metal. Seemed too easy to me to make the fiberboard panel not fit right.
Duckworth 08-24-2020 12:48 AM
As a last option only imo. Even if a few db sneak past the door, the benefit is likely to be negligible.
I once took a 1500 Spitfire, producing some bass resonance in the cockpit, while eliminating possible items like engine mounts and exhaust. After determining thin floor metal was a factor, sheets went down over it. But afterward, the gain was much less than expected, where the sound difference improved 5 - 10%. Many folks install the stuff in their cars, but it's not for everyone...
manuyc 08-24-2020 06:55 AM
ty guys.
