86 trans issue, low vacuum
Hello Folks,
It's been a while since I posted anything. I have 1986 928S, I think there is a picture in the Gallery. She has about 111k miles and I have had her for about 5 years. My problem is she has decided not to shift out of 1st, but if you run it up to about 6000 RPM, SHE WILL SHIFT INTO 2ND. No way to run a Rail Road, gets mighty scary fast. I had this problem before and it was a bad vacuum line from the Manifold to the trans modulator. I checked this line and it is good, using my mini vac I determined there is no leak in this line. Using my vacuum gauge, I only get about 5# of vacuum at the modulator at idle, virtually no change in vacuum with increased idle. I have tested the modulator with my mini vac, she begins to open at 7# and is fully open at 12#. My problem is not enough vacuum? I checked the vacuum at the intake manifold, the port that feeds the power brake booster. 18# at idle and 22# @ about 3000 RPM. I have checked all the lines at the Spider Junction, all are attached. Every time I reattach the MAF, air breather I was pulling vacuum lines off. The lines under the manifolds are impossible to get to, so I might have a leak there. I might have to remove the intake manifold, looks nasty. Any idea would greatly be appreciated. Do the limits on the Vacuum Modulator sound correct. 7# BEGGING TO OPEN, 12# FULLY OPEN?
Old 09-15-2020, 10:07 AM
I forgot to mention in ,my post. By using a long piece of vacuum house, with thew car on floor jacks. I can use the mini vac to activate the module and the car will shift. its shifting soft, but that I can be adjusted with the adjusting lever on the modual
Old 09-15-2020, 01:28 PM
stepson's Avatar
p930man,
With that same Mityvac, and since the transmission vacuum is connected via the 3/4/5/6 way vacuum connector back by the brake booster, you can check the other vacuum lines to see which line is bleeding off your necessary vacuum.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-16-2020, 09:08 AM
