Suspension settings for the track
Anyone like to share their starting point for a track prepped S4?
Cheers |
Ft toe - 3/16"" out total
Front camber - 1.5 degree negative Front caster - same Rear toe - 1/16" in total Rear camber - 1 degree negative That should be a good starting point. Adjust camber by tire temp readings, or wear readings. Front toe out gives better corner entry. |
great, thanks
there are so many variables but with my car which weighed 2600 lbs, 800 springs front, 350 rear
i used the following: alignment -2.5 f camber -1.5 rear 1/8 toe in front 1/16 to in rear i also had adjusted the bump steer with custom toe rod ends. You might find info here plus I have lots of stored pics Mark Anderson - Stroked 1988 928 S4 |
