1986 Porsche 928 s2
HI
Cant get heater blower to come out of footwell vents. plus in the footwell vents as lot of debris. looks like foam
Old 01-27-2025, 09:59 AM
stepson's Avatar
That foam looks stock. None of the cars I've dealt with had that much foam remaining, but I could tell that the foam had been there in the past.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 01-29-2025, 08:32 AM
Thanks for replying.
Are you saying that it is normal.Does it matter that the foam is no long there.
Old 01-29-2025, 09:58 AM
stepson's Avatar
porschedavid,
About the only thing left in MY vents is the glue used to secure the original foam in the vents. Most of the foam has previously exited the vents when the heater/AC was turned on. If the foam is blocking the air passage, you could trim it out of the way. I've never seen a 928 with that much foam still remaining.
Old 01-30-2025, 02:53 PM
HI
Will i have to take heater box to pieces to fit new foam or is it ok to use without
Old 01-31-2025, 10:25 AM
stepson's Avatar
My cars no longer have the foam. They work just fine as far as I can tell.
Old 02-03-2025, 07:38 AM
Linderpat's Avatar
I agree with John. Most of my sharks were foamless - I ended up shop vaccing it our to cut down on the dead foam dust everywhere. Never had a noticable issue.
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 02-05-2025, 12:31 PM
stepson's Avatar
Ed, I used a vacuum cleaner on the remaining foam as well
Old 02-06-2025, 08:11 AM
heater blower
Old 02-13-2025, 01:37 PM
i have a vaccum claener
Old 02-13-2025, 01:39 PM
stepson's Avatar
If your AC/heater is not directing the air flow to where you want, you might need to check the vacuum manifold under the console that controls the vacuum actuators that move to redirect the air. Access that from the driver's side panel. Remove it and find the multi-colored vacuum lines that go to each actuator, check that they hold vacuum. Additionally, check the black rubber vacuum manifold itself for cracks and splits.
Old 02-14-2025, 10:10 PM
