-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   turn signal return (http://forums.pelicanparts.com/porsche-928-technical-forum/1103489-turn-signal-return.html)
harborman 10-02-2021 06:05 AM
turn signal return
Hi All. I have not been on here for awhile. My left turn signal will not return so I have to move the lever manually. The right one works fine. Any idea what happened. I has on rare occasion reset itself after I make the left turn.
Thanks,
Rudy
stepson 10-03-2021 10:21 AM
What happens is the plastic piece in the switch that clicks the return(the signal canceller) wears down after many years of NASCAR driving. One "fix" is to remove the turn signal stalk assembly and put a few wraps of plastic tape around the canceller to build that area back to a level that it will work again. It doesn't take a lot to build it back again
harborman 10-04-2021 11:14 AM
Thank you very much for the fix!!!!! Much appreciated!!!
harborman 10-06-2021 06:48 AM
Looks like maybe one screw under the plastic cover to get to the turn signal switch?
