Running rich (smell rich)
Hi all fellow Pelicans, SmileWavy
My Porsche 928 S2 from 1985, is running pretty stable in IDLE and in general seems to run also fine when driving around. But there’s a smell behind the car (coming from the exhaust) that it seems to be running rich. And if a friend is driving behind me in his car, he’ll typical when we stop and talk say “your car smell like an environmental hazard”. :-/ So it seems the problem is there also not only running in IDLE. Does any one know of a “checklist” of stuff to walkthrough for finding root cause of such a problem? I did already change spark plugs, ignition caps/rotors, air filter, engine oil, water pump, timing belt, coolant. Thx in advance. BR Chris |
Maybe some things to check would be the MAF, O2 sensor, Maybe the Ignition module. They make a special cleaner for the MAF.
Hi,
Thx for the answer harborman, I appreciate it. I’ve tried cleaning the MAF with break cleaner, I wasn’t aware there was a special clear? Where do I get that? Regarding the Ignition module, I haven’t looked at that actually, what do you recommend I do to investigate that? O2 sensor, I don’t think mine car have a O2 sensor, I’ve looked at the x-cross section of the exhaust and there’s no O2 sensor to see. Unless I look the wrong place? |
Harborman,
S2s don't typically have O2 sensors. None of my 3 have them. Definitely agree with the checking the simple things first. |
Does your car have the cat on it? Has it been gutted, maybe by a PO?
My 82 stinks to high heaven, but she has no cat..... |
Hi again,
Sry for a few days silence on my side. Been alittle unexpectedly busy. Mine for sure dont have cat anymore, I replaced it with x-pipe instead. There was no O2 sensor. And the car was running rich beforeI did this exhaust change, so shouldn’t be the reason of the “running rich” problems. Maybe the O2 sensor came in 1986, if your car, Harborman, has an O2 sensor? |
