Need help with ac relay
Hi all I believe my ac relay inside the control unit has gone bad. I’m trying to determine what relay is needed to make the repair. Looks like the radio shack one everyone references has been discontinued since I think they went out of business. Does anyone know another relay that can be used?
Used one I bought from Amazon. Followed the other forum on rewiring and it works fine. Just look at how to wire and you should be good. It is a 12v, eight pin, with abase you don’t need. 10 amp. So added a in line 3amp fuse at freeze switch on the plastic cowl cover.;)
Amazon. 12v 10amp. 8poles. Only use 6 per
| All times are GMT -8. The time now is 08:40 AM. |
