E Sully's Avatar
1991 Running Rich
I have a friend with a 1991 928. Mileage is only in the low 20 thousand range. It was stored for a while but came out this year.
The shop has sent out all the electronics which check out good and has a new MAF.
It does not like to idle and can be driven but runs rough. The belt has been changed and timing is good. Fresh gas and fuel pressures all measure good. Problem is it seems to run rich. The spark plugs are all on the dark side from carbon. Temperature and other sensors test good. Could it be all the injectors are in need of cleaning, replacing, or possibly a relay?
Suggestions?
Ed
1973.5 T
Old 12-02-2024, 10:29 AM
harborman's Avatar
I would run a couple of bottles of Techron in it. See if that works.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 12-03-2024, 07:21 AM
stepson's Avatar
E Sully,
Check to make sure the correct spark plugs are being used. Don't use the platinum or iridium plugs. There have been reports in the past about idling and running issues with those versions of spark plugs. Just use good old copper plugs
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 12-03-2024, 09:30 AM
Also it would be worth checking the vacuum lines attached to the fuel pressure regulator and dampers to ensure you don't smell any fuel in them . if the diaphragms start to leak on any of them the fuel pressure will still be in the correct range, but you will get extra fuel drawn in through the vacuum system and this will cause rich running.
Old 12-13-2024, 09:39 AM
E Sully's Avatar
It turned out to be injectors. It started to run better after some mileage with cleaner added. They are being sent out, and hopefully cleaned and re-used.
Ed
1973.5 T
Old 12-13-2024, 12:27 PM
harborman's Avatar
Did you use the Techron cleaner ?
1986 928S
32 valve engine
Old 12-15-2024, 05:38 AM
E Sully's Avatar
Drained tank and used Techron with fresh gasoline. It was improving, but want the injectors tested and cleaned to make sure it runs as good as possible.
Ed
1973.5 T
Old 12-15-2024, 10:54 AM
harborman's Avatar
All I would do is run a few more bottles of Techron in it and drive it.
1986 928S
32 valve engine
Old 12-17-2024, 05:53 AM
E Sully's Avatar
Owner wants them serviced. He'll feel better after seeing the spec sheet showing flow and spray pattern, and if any fail will want that addressed. It's only money, and the car is in great shape.
Ed
1973.5 T
Old 12-17-2024, 12:42 PM
E Sully's Avatar
There is a Service Bulletin on using Techron.
Ed
1973.5 T
Old 12-17-2024, 12:57 PM
harborman's Avatar
All I am saying is the Techron did the trick on my 928 which had been in storage a long time. It is a simple fix. No need to spend a lot of money.
1986 928S
32 valve engine
Old 12-18-2024, 05:39 AM
