Tim Boyer's Avatar
Drain gas tank
Hi
I need to drain a gas tank on a ‘84 928. Is there an easy way to do this?
Thanks,
Tim
Old 03-15-2025, 04:37 PM
honerboys's Avatar
been a long time since i drained a tank - if i remember i think i just siphoned out as much as possible - then i pulled the hose off the pump and ran the pump into a container - then i plugged the line out of tank and pulled the tank - it still had some fuel in it but it was not too heavy - not sure if this is the easy way - be careful
84 928 S - SOLD
2012 Cayenne S
Old 03-17-2025, 08:37 AM
Kyle C
I just did this on a 1984 928S for a friend. I usually drain them right at the tank outlet. There is a short molded hose right off the bottom of the tank that feeds the fuel pump; if this hose is old or original, plan on replacing it. I use plastic hose pinch-off pliers on that short hose, disconnect it from the pump, and then open the pliers to allow fuel to drain into a collection container. You may need to loosen the fuel filler cap to allow it to drain properly. When you need to switch containers, just pinch off the hose.
Will you be removing the tank completely, or servicing anything else while you're in there? I'd recommend inspecting the strainer in the bottom of the tank. In my case I removed the fuel level sender and used a flashlight to look inside.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 03-18-2025, 04:45 AM
Banned
Draining the gas tank on your '84 928 can be a bit tricky, but it's doable with the right approach. One easy method is to use a fuel pump siphon kit, which allows you to pump the fuel out without needing to remove the tank.
Old 03-27-2025, 04:54 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
On my '78 I just used a long fuel line hose and put in the tank from the fuel filler. These old cars are easy to siphon fuel out of. Old school way from my gas station days in the '70's suck till it flows, then into a gas can...
That gets most. Then do the rest from the back of the tank under the car. 2 remaining gallons there seems safer than having 20 gallons gush out...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 05-05-2025, 05:55 PM
Banned
Easiest way is to pull the fuel pump hose and use it to drain, just jump the relay to run the pump.
Old 05-12-2025, 08:28 PM
Cobalt's Avatar
Connect a line to the fuel line manifold at the tap port and as Betis914 said run a jumper with a switch to the pump relay in the fuse panel and pump it out. I do it all the time when my car sits for more than a few months.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 05-15-2025, 04:13 AM
