Rickster
huskerick1's Avatar
WTB - S4 Bosch injectors
Looking to buy used 87+ S4 injectors, Bosch # 0280150730.
Please PM. Scammers need not apply...
Rick
1989 944 Turbo S - Slate Gray
1989 928 - Slate Gray
2015 Panamera Turbo S
2005 Corvette Z51
2011 Harley Heritage
Old 08-26-2025, 07:55 AM
stepson's Avatar
Be very careful with injector replacements. There are a whole slew of what looks like Bosch replacement injectors that are Chinese built. They will install just fine but your car will not run correctly.
Unless it's someone you know that can verify the injectors, I would tell you to buy from a reputable 928 parts dealer to minimize the danger of Knock-offs
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-26-2025, 09:33 AM
Rickster
huskerick1's Avatar
two scammers to avoid:
Bridwell
Audiblypry
will post more as they foolishly continue their efforts...
2005 Corvette Z51
Old 08-26-2025, 05:17 PM
Rickster
huskerick1's Avatar
Agree 100% - i rebuild these, as well as 944/911 injectors, and would agree you are spot on. The only versions that perform well - in my opinion - are the originals.
2005 Corvette Z51
Old 08-26-2025, 05:19 PM
stepson's Avatar
I replaced the injectors on my GTS with what I thought were original Bosch injectors while doing a bunch of other stuff around the intake. The car ran great before the work and ran like doo after. After undoing all the work I had done while trying to figure out what went wrong, I was left with the "new" injectors. I reinstalled the original old injectors and it ran great again.
You learn something every day working on these cars.
Old 08-29-2025, 01:20 PM
Do you think the newer style 4 hole pintle work better than the oem installed
Injectors ?
Old 09-01-2025, 11:52 AM
Rickster
huskerick1's Avatar
Injectors ?
Dan,
Depends... if one gets a quality set of 'real' 4 hole injectors, I suspect they will perform well. That said, the market is littered w/off-shore and counterfeit injectors that are garbage.
I am a fan of the OE parts... once cleaned, good for another decade or two.
2005 Corvette Z51
Old 09-01-2025, 01:06 PM
