Hoses and cannister under front fender?
I have a 1979, the braided hoses under the front fender have dried and cracked and need replaced. There's also a cannister under there, is this another fuel vapor cannister? My question is what are these for? One runs through to the engine compartment, possibly entering the air system/filter box? The other other runs into the body heading towards the rear, to the fuel vapor cannister?
Finding a clear diagram or explanation of these hoses is difficult. Can anyone help please!!
Old 08-16-2025, 02:01 PM
what you’re seeing are vapor lines not fuel delivery lines. They’re important for keeping fumes under control and preventing fuel smell in the garage.
Since your hoses are cracked, it’s worth replacing them with proper vapor hose. The cloth braided stuff looks factory, but you can sub in modern smooth hose as long as it’s spec’d for fuel vapor.
Old 08-17-2025, 03:12 PM
Thank you
Where do they go to and from? I can't find any diagrams for them that clearly show where they connect to.
Thanks again
Old 08-17-2025, 03:35 PM
Kyle C
They should be depicted in a few places:
-emissions decal under the hood (shows the vacuum line routing and emissions device hose routing)
-owners manual (I think mine had an overall diagram explaining the function and layout of major components in the emissions control systems)
-workshop manual - if you don't have a copy, it can be found online in PDF format. An invaluable resource for servicing your 928.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 08-18-2025, 05:55 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
I just did this last weekend on my 1978.
There are three connections on the charcoal cannister.
The hose is easy to buy - here on Pelican, on Amazon, or 928srus, just measure the inside diameter, but make sure the outside diameter isn't so large it won't fit through the openings.
The critical one to replace is a nightmare, or was for me. I believe it's the 3/8" I.D. hose (or 9.5 mm) It took around 8 hours of frustration as everything is so tight, or requires removal. It routes from the cannister in through the side, then tightly under the coolant overflow tank, and then down to a metal fitting, which goes back to the fuel tank overflow section. Mine actually started leaking small amounts of fuel, so I had to replace.
A second hose goes through and then connects to the air filter box (whatever that's called)...
My third hose doesn't go anywhere on my car, but I think it was ssupposed as it's a vapor release...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 09-25-2025, 09:05 AM
