88_944's Avatar
Can the 944 engine take 6000 RPMs?
I was thinking of getting a Weltmeister Performance chip that gives a 15 hp @ 6000 RPMs and I was wondering if the engine could handle the high RPMs without damaging. I think because the 944 has no rocker arms setup, 944 could take more RPMs.
I finally got an intake!
My Black 944
My Gaming Forums. Xbox360gen.com
Old 12-24-2003, 11:36 PM
exc911ence's Avatar
6000rpm? Easily... I bounced my old car off its rev-limiter all the time with no problems. Just make sure those timing belts are new!
1979 911SC "Frankencab"
Dave
Old 12-25-2003, 03:56 PM
if you have over 100K miles and haven't replaced your rod bearings I wouldn't do it too often. the rod bearings starve at high rpm
Old 12-29-2003, 02:21 PM
not-banned
My car may be a 16V but the lower end is the same as the 8V:
Old 01-22-2004, 11:28 AM
the temperature gauge is doing the same thing as the tach!
Old 01-22-2004, 11:36 AM
I would be woried about that oil pressure at 4.2 at these revs if it was my car.
Hope you did not take the photo while driving at this speed.
Greetings
Johan
1990 928 S4
Old 01-22-2004, 11:37 AM
not-banned
Don't ask what happend a month later.............
The motor had almost 112,000 on it. It was due for a rebuild anyway.
Old 01-22-2004, 11:38 AM
that's pretty low mileage for a rebuild, I restate my case: if you have over 100K miles and haven't replaced your rod bearings I wouldn't do it too often. the rod bearings starve at high rpm
Old 01-22-2004, 12:23 PM
not-banned
Right after I hit 112k, a rod bearing bit the dust.
This was 5 months after I installed a new head. When I say new I mean:
1. new valve guides
2. new cams (chain broke, de-toothed mine)
3. new tensioner
4. new chain
5. valve job
I was ordering the parts for the chain/tensioner replacement when that blew.
Old 01-22-2004, 12:47 PM
Uh, is that a 15hp gain @ 6000rpm on a 944NA? Tell you what, I'll PAY for your chip-upgrade AND your dyno session if you can do a before and after comparison of that chip vs. the stock chip and have it show a 15hp increase. Stock '88 944NA should be putting 125-130rwhp and if you get +15hp over that with just a chip upgrade, I might just buy that car off you as well. Gonna go 944-spec racing and won't those boys be surprized by my secret weapon, heh, heh... on
Old 01-25-2004, 09:35 PM
Yes, put me down as wanting to see that dyno as well
Auto Free Finders "peoples marketplace" better value then dealers!
Old 02-03-2004, 12:08 PM
Iggy's Avatar
Is a moderator EVER going to move this thread to the correct forum???
Old 02-06-2004, 07:17 AM
Schocki's Avatar
I run my 944 S2 on a regular basis on the Autobahn at constant 5200 Rpm's and never had a problem. I think that a continous speed of 6000 is no problem. Just watch out that ANY 944 will use oil at high rpm's. The reason is that the 3.0 liter engine gives the oil air separator a good workout at those speeds. By the way my car has 115.000 miles on the clock and runs without problems.
Michael
1972 911T Targa
1991 944S2
1992 928GTS
Old 02-07-2004, 07:20 AM
