"86 944 engine noise
I have rotating, metallic noise in the front of the engine. Thought it might be cam/balance shaft pulleys but after removing the cover and running the engine for a while it sounds loudest behind the crank pulley. Does this mean a bad bearing/bushing in the oil pump? Should I replace the oil pump? Any help would be appreaciated.
Old 12-24-2000, 03:29 PM
