Opening the hood
Hey guys I had the radiator fluid leak which seems to have fixed itself. There must have been too much and it leaked out the overflow, but after opening the hood 10 times last weeek to figure out the problem now I can not open the hood. I pull the release and there is resistance, but the hood latch does not release. It used to pop the hood up about 1 inch or 2 and then it could be opened, but now nothing. Is there any ideas on openong this thing up? Somebody please respond . I can tell if you look!
Old 06-06-2004, 05:19 AM
Iggy's Avatar
I haven't had to deal with this before, but I believe you can reach in from underneath (through the front grill) to pull the cable by hand. It's gonna take a while to figure everything out, but I'll try to find a photo of the cable routing so you know where to stick your hand.
Old 06-10-2004, 01:24 PM
Iggy thanks for all of the help. I was able to double team it. Had someone pull the lever and I looked underneaath and was able to give it a little extra movement and it popped right open. Thanks. I will also check about the fluid.
Old 06-10-2004, 02:17 PM
