-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   help- insulated bushing needed (http://forums.pelicanparts.com/porsche-928-technical-forum/270405-help-insulated-bushing-needed.html)
12magnum 03-07-2006 11:24 PM
Help,
12magnum 03-07-2006 11:36 PM
insulated bushing for belt tension warning
help please. I am in the middle of changing the water pump and timing belt on my 1986 928s. I sure am glad I'm changing the belt, because whoever changed it last put the timing belt tesioner together without the insulated bushing that makes the belt tension warning light come on!!! this joker put a plain washer in it's place, since there is no insulator, the metal parts are always in contact so my warning light would never go off. the bushing i am looking for fits between the tensioner spring and the tensioner grounding strap. I can't find the part listed anywhere. if anyone knows what i'm talking about, can you give me a part number, proper name for the part, or hopefully someone can tell me where to get one. Also if someone has one of these parts (new or used) I will gladly pay for it. thanks in advance.
mike
Rixter 03-08-2006 03:11 AM
call 928 Specialists, www.928gt.com
828-766-9280
12magnum 03-08-2006 06:35 AM
rixter,
thanks for the advice. I called 928 specialists and Dave was able to hook me up with the correct part. BTW the part i was missing is called a guide sleeve.
