-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Reverse - 81 928 Automatic not working (http://forums.pelicanparts.com/porsche-928-technical-forum/304873-reverse-81-928-automatic-not-working.html)
IXLOR8 09-17-2006 03:08 PM
How hard is it to repair this problem?
Does the transmission need to be removed?
Any special Porsche tools needed?
How many hours to remove? Repair?
Any idea on cost?
JandeVries 09-29-2006 07:25 PM
Can be adjusted, there is a nut on the right (passenger side).
If you adjust it with the wrench at 12 o' clock and move it to 5 minutes past one may be reverse gear could be back, if not try further, but only milimetres...
If this doesn't work or it gets worse overtime it looks like a tranny repair, or replacement...
IXLOR8 09-29-2006 07:59 PM
We have found that on a lift and in reverse that we can stop the rear wheels from turning. I have been told that it could be a band is out.
